id say its the glow plugs then whats the weather like where you are at?
I would agree, the seal on the fuel filter could be the issue, try and give it a 1/4 turn more unless its on really tight, as you don't want to strip it.You have air
I disagree. These trucks will still start when its 40* outside with the glowplug system completely disconnected.id say its the glow plugs then whats the weather like where you are at?
Also there are gaskets in the fuel filter housing that will crack and dry out and it will lose prime. That happened to ours this year and we had them replaced and no more losing prime.filter housing could be cracked causing it to lose prime seems to happen quite a bit on the duramax
I have had that issue on my 02. It was injectors and very costlyMy truck will not start. If I spray ether in the breather it will start and stay running all day. Could this be my fuel pump? If so I heard there are two of them. Where are they? Sorry, real new to diesels????
I’m new to this forum but have had my 02 all these years and I can say that mine would run after using gas rag to start but would not start without it after running for several hrs. Had four injectors bad. Then a few years later wouldn’t start thought oh no not again but it would not stay running once started. It was sucking air at fittings Driver side back of motor.I have had that issue on my 02. It was injectors and very costly
Yes its the high pressure fuel pump. Had to get mine replaced last year $$$$$My truck will not start. If I spray ether in the breather it will start and stay running all day. Could this be my fuel pump? If so I heard there are two of them. Where are they? Sorry, real new to diesels????
I replaced the sending joint in the tank, the fuel filter assembly, the two hoses coming out of the fuel filter assembly, and non of that solves the same issue. Finally gave in to dealers recommendation to have injectors replaced... that did not solve the issue. The mechanic at the dealer came up with a theory that the fuel was bad... still don’t know how that could relate to the issue but he said he drained the tank and replaced old fuel with new fuel. Truck has run great ever since. My theory is they found a leak somewhere else but won’t admit it. Might be worth a try to drain and replace the fuel. Could be a simple fix. Mine did seem to be more temperamental when I got to less than 1/2 tank so maybe the contamination was more concentrated. All I know is I’ve driven my truck about 2000 miles since the fix and it has not let me down. It’s tough and expensive when you’re chasing gremlins! Good luck!Just replaced the fuel filter and did not see any damage. This is puzzling. It acts like it doesn't have pressure when I want to start it but once it gets going I am good. How can that be the fuel pump. Sounds like it is probably something simple. Finding that simple is hard.
Revised ( typos corrected)
I replaced the sending unit in the tank, the fuel filter assembly, the two hoses coming out of the fuel filter assembly, and none of that solved the same loss of prime issue. Finally gave in to dealers recommendation to have injectors replaced... that did not solve the issue. The mechanic at the dealer came up with a theory that the fuel was bad... still don’t know how that could relate to the issue but he said he drained the tank and replaced old fuel with new fuel. Truck has run great ever since. My theory is they found a leak somewhere else but won’t admit it. Might be worth a try to drain and replace the fuel. Could be a simple fix. Mine did seem to be more temperamental when I got to less than 1/2 tank so maybe the contamination was more concentrated. All I know is I’ve driven my truck about 2000 miles since the fix and it has not let me down. It’s tough and expensive when you’re chasing gremlins! Good luck!
