1 - 2 of 2 Posts
I have an 03 duramax and I live in Florida.
I've been having problems with the filter losing prime when I park up hill. this usually only occurs on cold mornings (40's)
I had a leak at the o ring fixed that. Napa filter, had problems with adding Lucas treatment Clogged the filter.
Also I am getting a rough idle and a little vibration @ 1500 RPM range going through the gears.
I have seen plugs to remove the water in fuel sensor. is that a good idea or not? If I can run safely without the WIF sensor. is there a Fuel filter without the fitting on the botom that will fit? if so what is the part # and where can I get one?
Is the part # for the stock fuel filter TP 3012?
I am also reading that I need to replace the rubber fuel lines. 1/2 inch and I would need about 3 feet? any recomendations of line?
This is a bone stock work truck
You got a few options.... You could either rebuild your current filter head, remove your current WIF sensor, or for nearly the same price get a CAT adapter. Its a special adapter that makes it so you can use a CAT filter on your stock head. the CAT filters are better and take out more garbage.
Rebuild kit:
FILTER HEADS AND REBUILDS : DMAXSTORE.COM, Your Duramax Diesel-Only Shopping Resource
Also, If you add a lift pump you will never have to prime again! It will also replace all the lines from the gas tank to the motor :cool:
100% free webcam site! | Awesome chicks and it is absolutely free! | Watch free live sex cam - easy as 1-2-3
1 - 2 of 2 Posts
