1 - 20 of 25 Posts
Found a truck on craigslist that i think im going to buy
Its a rclb lly 260k on truck 130k on motor
Its an ls has leather
I currently have a 95 3/4 ton gasser for plowing that i want to replace
Hes only asking 7300 obo
Let me know what you guys think
If you got papers on the engine replacement then ya k would scoop that up.
Yep says he has paperwork
It was a replacement not a rebuild
Also its a 1 ton
I think im going to hang a 8.5' western mvp3 on it
Should make a nice all around truck
:thumb
Nice truck
Regardless of engine replacement if thats a 4x4 its worth it if the Injector Balance Rates check out. Get the torque app and a bluetooth adapter off Amazon and check it out before you buy! And its an LLY so check out the smoke situation to make sure the headgaskets are stout. :thumb
Also: The duramax will insult that old 350 gasser so bad you'll won't believe you ever got by without it. I have a red RCLB. Sweet truck
I planned on plugging my insight in and checking it out
Can u elaborate on smoke situation not sure what u mean
I know what u mean on the 350
I got a 18ft gooseneck dump trailer that weighs 8k empty so i have to use my lbz to pull it cause the 350 would crap 3 pistons and a tranny if i tried it with that haha
Just make sure it doesn't smoke white on start up. Some signs of sketchy seller: Always warms truck up before you come look at it. Tell him you want to see an overnight cold start. Diesels are strong engines, have a bad habit of seeming fine some times, and puking their guts soon after
Just texted the seller and asked he not start it before i get there
He said its parked in his heated shop and said he would pull it out and let it sit outside if i wanted
He knows im driving 10 hrs and hes been very thorough about the truck so i think its coming home with me:neener
That One Guy
To verify its an LLY make sure the 8th VIN number is a 2. Like stated above make sure injectors check out and it runs good and you'll be very happy then!
8th digital is a 2
Sounds like it might have been taken care of, could be a steal.
Discussion Starter · #15 ·
It was a steal
Needs nothing mechanical
Im 2 hrs from home with her
Time to start buying goodies
:drink
Discussion Starter · #17 ·
The truck runs awesome drives like its new
Might need a wheel bearing other than that some simple interior stuff
Its going in this week for a b & w gooseneck this week
If its a tan interior, I have a whole tan regular cab interior I'll hook you up with for whatever you think is fair.
Thanks but its charcoal and its in really good shape
It just needs a headlight switch (cant turn on the dome light manually)
And a heater control (passanger side adjustment is broke)
Other than that it just needs some go fast goodies
That's a nice truck!
Good job :thumb
1 - 20 of 25 Posts
