I have a 2005 GMC Duramax diesel and have recently been having a no start problem. Last week I parked my truck in the evenining, the folowing morning it would not start. It turned over great but would not fire. I checked the electrical connections under the hood and tried again, still would not fire, primed the fuel filter and tried again, still wouldn't fire. Finally had the truck towed to the shop. They hadit for the day and said the found a bad connection in the plug connections under the hood. Took the truck home, ran fine, next morning started fine and ran well all day. Parked it Friday evening, went to start it monday morning and same thing, turns over well but won't fire. I unplugged the connection they had told me about and retried after every check I made, wouldn't fire. Had it towed to the shop. They said after it was unloaded they tried it and if fired right up. Ran fine that afternoon, parked it that night and started it the next morning, ran fine all day. Parked it at night, next morning it wouldn't start. Repair tech came to house late afternoon, tried it and it fired right up. Truck is currently still at the shop as they have not been able to determine the problem. Anybody else heard of such a problem?? The truck does have an Edge chip in it, we removed it from the system and tried to start it several times when it wouldn't go and it still wouldn't fire. The GM shop could not find any codes on their scanner any of the three times to help with diagnosis either. Any help or suggestions would really be appreciated.
Thanks
Thanks
