Year:2005
Make:GMC
Model:Sierra 2500 HD Crew Cab
Mileage:79000 M
Transmission:Automatic
Engine:6.6L Duramax
Trim:Custom
Truck for sale with CA Title in hand. Lots of options and add-ons. Please message via text first, I will not answer unknown phone numbers.
Pics available on Craigslist 2005 GMC Sierra 2500 HD 4WD Crew Cab 6.6 Duramax - cars & trucks -...
Runs and drives great. No issues, noises, or vibrations while driving. It does go through gas quickly but it seems to average about 12.2mpg combined freeway/city driving.
Good used condition. Inside the cab shows light wear and tear while the exterior shows normal wear and tear for a 17-year-old truck. Color is listed on the build sheet as Sand Beige Metallic and the interior was put in as cloth, so no cracked leather. There is a small burn mark on the driver's seat. The back seat doesn't look like anyone has ever sat in it. Truck is animal-free its whole life. Optional factory Bose sound system is installed and sounds great.
6.6L Duramax with less than 80k miles. The turbo was rebuilt last November. Everything in the engine compartment is stock / California smog compliant. One of the batteries was replaced last April and the other this past March.
GVW: 9,200lbs
Rear Axle 3.73 ratio
Allison 1000 Deep Transmission Pan
Suspension upgrades:
Fabtech 8" Performance Suspension System
Fabtech FTS51003 8" Multiple Front Shock System w/Billstein Struts
Fabbtech CC SB Traction Bars
Firestone Ride-Rite Air Spring system
4x Tires + 1x Full size spare:
Hutchinson / Rock Monster Wheels WA-1174 17.5 x 8.5"
Yokohama Geolander 37 x 12.5 R17 LT 124R 8PR Tires
Aftermarket upgrades:
Warn 16.5ti Winch (no controller)
AMP Research Power Step
IPF SuperRally Lights
Pioneer Navigation System & Rearview Camera
Line X spray in bed liner that still looks new
All 5 volumes of the GM service manual for this truck will be included. These books are genuine originals and are incredibly difficult to find copies of.
I have the original build sheet from the factory and have a cool story about one of the guys who helped build it at Flint Truck&Bus.
Hypertech Power Programmer - This truck has been programmed for its tire height so that the MPH and mileage can be properly recorded. No other reprogramming of the ECM has taken place as this will void its ability to pass CA Smog. It has not been used since the tire height was reprogrammed so I am not sure if this module is still working or not. It will be included.
Things that may require your attention:
-Headliner fabric is separating which is typical for GM cars this age
-CD Player will not accept a CD being inserted
-The navigation system is terribly out of date, but the backup camera works fine still
-AC is not blowing cold, it worked before the turbo rebuild so I am guessing a hose has a leak in it or the mechanic drained the system
-Occasionally the PowerStep does not go down when the door is opened, I have to open and close the door again before it goes
-Brush Guard Lights do not work, I found a wire that had a corroded termination and I recommend replacing the whole wire
-Missing the controller for the winch, unsure if it is fully functional or not
Registration on this vehicle expires at the end of the month (April), so I'd like it sold to the new owner before then. There are no outstanding fees or tickets on this vehicle outside of registration.
6193075952
[email protected]
