1 - 11 of 11 Posts
Hello, I have a 2005 LLY, it is studded, deleted with an older edge racing tuner, EGR deleted, has all new injectors, new cp3, race fuel plug, and all new hoses on the fuel side and a FASS 150. 90% of work has been completed in the last 2 years by myself and a friend who's a mechanic. I am just a self taught wrench Turner
My problem started about 6 months ago pulling a small trailer with a UTV on it. Driving 70 mph, I noticed the truck was not pulling up an overpass like usual, looked at my programmer and my DFRP was 22k VS FRP which was at 7k. Over the course of the drive home it did the same thing one or two more times. Now 6 months later it will do it every time I accelerate with any boost and will not build pressure above 17k on it's own. After it gets to 17k psi or so it immediately drops FRP to 3 or 4 k and I let off the throttle. I have checked fuel lines till I'm cross eyed, changed the tune, drove it on stock setting for weeks and have changed fuel filters and water separators twice.
A mechanics shop has it right now and they have ran diagnostics on the injectors, FASS, CP3 and all come back normal.
The mechanic told me yesterday he can command 27,000 psi to the pump and it will maintain it no problem. Return fuel rates from injectors are normal and he can not find any fuel leaks anywhere.
Injectors are stock from Diesel Logic
CP3 is reman from Bosch
Any help is greatly appreciated.
Discussion Starter · #2 ·
Hey guys any help is appreciated. The truck has been in the shop over a month with no end in site. I did the head job, installed the cp3 and installed the fass system. Still trying to figure out what would cause a low fuel pressure issue at higher power demands.
I would think it has to be an air leak . Have you pulled the gas tank down recently ? I ask because I had similar issues and couldn’t find a leak for the life of me . Then when I pulled the tank off , the fuel sending unit was leaking . It looks as if it is normally soldered on and the solder broke . Once I replaced it with a new one , problem solved !
I did not pull the tank. The mechanic thought the fuel deliver was restricted somehow so he pulled the tank and removed part of the sending unit I think ? It has a fass 150 installed. I will relay to him the comment. Thank you for your help.
Well so far not good. I've been on orders for the military and out of town for the last 3 weeks. My mechanic still hasn't figured it out. At this point I'm ready to tear it apart myself and change the cp3. Any other ideas ? I'm all ears. Not sure what to do ..... I've got over 13 grand in it after purchase price now....cant really sell it as is tho .... any help is greatly appreciated
Got the truck back today. The injectors check good, the cp3 checked good as well. The mechanic said he suggested I change the fuel pressure sensor and the fuel pressure regulator. Other than that he has no ideas to offer. Any help or ideas are appreciated guys.
I would start swapping the fpr and fprv.
Did you ever find out the problem?
My trucks doing the same thing up grades loaded / empty
· Premium Member
Change the FPR on the cp3. See if that helps.
New Bosch FPR put in last month when the truck was surging at idle.
I have a good hunch for this issue, have a stored code for open EGR, I command it to 30% and it will only go to 22% and then bounce all around from 15-23%.
Command it closed and it only goes down to 3%. So this is causing low boost but not low enough to cause a code. The truck is great and has power when "cold" will get 15-20psi of boost with ease, but once the EGR cycles for an open loop / closed loop it looses power and won't build boost above 8% without me putting the pedal through the floor
1 - 11 of 11 Posts
