Year:2005
Make:GMC
Model:Sierra 2500 HD Crew Cab
Mileage:194000 M
Transmission:Automatic
Engine:6.6 diesel
Trim:Slt
List of new parts
Fass 100gph
Nylon return lines
S&B cold air intake
S&B intake elbow
Mbrp 3 inch down pipe
Mbrp 4 inch full exhaust
Lower control arms
All 4 shocks
Front pads rotors and wheel bearings
Power steering gear from redhead 18.1 ratio
Gm power steering pump
All new power steering lines
Steering shaft
Pitman arm
Idler arm
Tie rods
Both thermostats
2 new glow plugs
1 bose speaker
Dash cluster replaced with reman unit with correct mileage and vin to it has a lifetime warranty
20% tint
Bed, doors and fenders replaced with southern panels.
Bed was repainted and undercoated in por15 same with fenders, frame and cab where I could.
The bad may and this is a big maybe need one fuel injector. #4 injector is reading -5.2 fuel trim. Normal operation is -4 to +4. Does not throw a light. But can hear the miss a bit. Been adding more fuel additive and some at fluid to help try and clean it out. The rest are all within spec. Can show you fuel trim so you can see for your self.
Other than the one injector. The bumpers are pretty crappy. Aka you can see the rust on the front.
Otherwise runs great, drives great. By no means a perfect truck. The rockers and cab corners could be redone. But she is a good truck. Getting a newer diesel and don't need this.
