1 - 7 of 7 Posts
will a 2006 grill fit a 2003 truck???
Hi, I'm Earth. Have we met?
You'll have to use a 05+ hood if you change the grill also!
05 lly any ideas on hard starting
Could be a number of things, i would start with a new fuel filter if it has more than say 6-7 k on it! Injectors are quite common on the lb7 engines, but there are usually other symptoms.
Another thing could be a cracked filter bleeder screw(little black nut/screw on top of the filter housing), causing fuel to drain back to the tank whle not running.
Discussion Starter #6
It did work i had to use the newer hood. Thanks guys
Looks good, thats on my list of things to do to my wifes truck, someday!!!!
1 - 7 of 7 Posts
