2006 Chevy Silverado 2500 HD 4X4
6.6 Duramax Diesel LBZ
6 Speed Allison
1GCHK23D46F192987
88K
$34,000 OBO
Mechanicsville, MD
Here is a link to all the pictures I have, I can take more if needed.
https://photos.app.goo.gl/yDKzTd8HE6wbakiu9
Short Video of the truck:
https://www.youtube.com/watch?v=ufNpOfKkMYI&t=21s
Finding an LBZ in this condition is unheard of, especially with such low miles! This truck is equipped with a Regency Remington Limited Edition Conversion from the factory. I had heard of Regency Conversions before but never the Remington Edition. After doing some research and contacting Regency, there were only 308 (.308 Bullet) of these trucks ever made in the year and a half of the LBZ era and only 50 were made with the black leather (The rest being the King Ranch style brown leather) The conversion started with an LT3 Crew Cab and included:
4" Sky Jacker Lift with off road performance tuned shocks
Pro Comp Series 6031 HD Wheels
Two Tone Paint (LT Titanium 4121 Color)
Custom Pin Striping with matching Remington Logos on the tailgate and door handles
Heated seats are 100% upholstered in saddle grade leather and have custom "baseball" stitching with built in felt lined map pockets on the back of the front seats
Headrests and console are custom embroidered with the remington name
Chrome billet grill
Color match grill surround
Color match Bow Tie emblem
Color match Tow Mirrors
Color Match Fender Flares
Custom Remington gauges with red lighting
The original owner bought, serviced and traded in at the same dealer and had the entire frame undercoated from day one. The CarFax maintenance history shows every oil change the truck has ever had along with the full 50K service/fluid flush of ALL fluids done and 27 other service records. I also had the dealer print out their entire record of service receipts. The original owner was an older gentleman that traded it in on a 2016 HD. It was obviously babied and garage kept, the beds paint is in as good of condition as the body paint. There was a bed cap and bed rug on the truck since new however they were both removed when traded in.
Since taking ownership I have done the following:
BRAND NEW all original PYO wheels and Chevy Lug Caps in a triple chrome finish (Everything coated with Kamikaze Stance Rim Coat)
BRAND NEW Toyo Open Country 285/70/16 Tires
Curt Class V Receiver Hitch with 7 and 4 Pole connector socket and mounting braket
Trailer Brake Controller
BakFlip MX2 Bed Cover with BakBox Tool Box
LineX Bedliner (Lifetime Warranty) Through any LineX Dealer
Dee Zee lazer cut rubber bed mat.
Weather Tech Floor Mats Front and Rear
ATOTO Android Head Unit - Basically a tablet that can do everything a tablet can do, YouTube, Internet etc.
Back-Up Camera
All Wood Grain interior trim pieces have been replaced with Brand New OEM replacement parts (Was never a fan of the woodgrain)
All New Kenwood Excelon Front and Rear Door Speakers
GTR Lighting GEN 3 Ultra Series LED Low Beam Headlights
GTR Lighting GEN 3 Ultra Series LED High Beam Headlights
GTR Lighting GEN 3 Ultra Series LED Fog Lights
LED Brake and Reverse Lights with stock housings
ALL Interior lights are LED (Door, Map, Cab)
Bully Integrated Tailgate lock with color match bezel and handle. (When the cover is closed you can lock the tailgate and everything in the bed is secure. Not a stock feature on this generation GM trucks.
Fleece Performance All Lights On Module (Keeps Low Beams on when you turn High Beams
ALL NEW Dorman Motor Mounts and Body Mounts (This was a know issue on 01-07 trucks as there was a TSB. Body lines would sag and have an extremely rough ride. Now all the body lines and pinstriping match up perfect. DID NOT go with polyurethane mounts after tons of research. Felt the ride was going to be too rough and decided to go with the MUCH more expensive stock rubber replacements.
The truck has SunTek Ultra Clear Bra Paint Protection Film, FULL hood, headlights, and bumper.
FULLY coated in Kamikaze Miyabi and topped with Kamikaze ISM (Very high end ceramic coating, years and years of protection)
Excalibur Remote Start and Alarm
My end goal with this truck was to buy a boat for the family. I wanted to make it the most reliable, streetable truck on the road, as well as tp add a little more power and the turbo brake to help with towing. No truck is perfect from the factory but the LBZ is widely regarded as the best Duramax GM ever built with limited production to years 2006-2007.5. GM had finally worked out all the bugs, and best of all, it was the last generation GM truck Pre emissions and DEF. There were a few known issues and all of the modifications have been done to correct ALL of these, and have been done professionally. I will provide all documentation and receipts. The following has been done mechanically:
Merchant Automotive 10001 Transfer Case Pump Rub Kit (Known issue from 01-07)
Merchant Automotive Tie Rod Sleeves
FASS 150 Titanium Lift Pump with custom mount and protection bracket (Extra fuel filtration reassurance)
S&B Cold Air Intake
Deviant EGR Delete
Deviant Up Pipe
Deviant PCV Reroute
Magnaflow Downpipe
Magnaflow Aluminized Full 5" Exhaust with 6" MBRP Tip
PPE Fuel Valve and O-Ring Upgrade
TransGo Jr. Allison Shift Kit Upgrade with Full Flush and New Filter
Full Coolant Flush
ALL Brake Lines have been replaced
EFI Live DSP-5 Switch with Tow Tunes and Turbo Brake
I have always done 5K Oil changes with Rotella T6 Full Synthetic oil and a Mobil M1-303 filter. I also have an Oil Analysis done by BlackStone Laboratories which I will include. It shows no abnormal wear in the motor and no sign of contamination from fuel, coolant or water. I promise you will not find a cleaner and more well taken care of LBZ out there. Not to mention the Limited Edition Remington Package with only 50 ever made with these options. NEVER raced or abused, just a weekend truck that has never seen rain since the day I brought it home.
Unfortunately with a new house and a bigger family now, I just can't justify seeing it sit and paying insurance on something that I rarely ever use. I have all the original manuals, both remote start key fobs, both original key fobs, and all receipts and documentation with original CarFax and Title in hand. If you have any questions feel free to call or txt. I will include as many pictures as I can but if you need others just let me know. Will help with shipping as well if needed.
$34,000 OBO
Thanks for looking!
6 Speed Allison
1GCHK23D46F192987
88K
$34,000 OBO
Mechanicsville, MD
Chrome billet grill
Back-Up Camera
S&B Cold Air Intake
Deviant EGR Delete
Deviant Up Pipe
Deviant PCV Reroute
Magnaflow Downpipe
Full Coolant Flush
$34,000 OBO
Thanks for looking!
