Hello,
New here but NOT new to these trucks. Bought a 2006 2500HD with a bone stock LLY Duramax about 10 months ago. Driven daily with no issues. The truck has 200K on the odometer. Yesterday I drove it to the store and when I got home I was backing it in the driveway and it stalled (Allison 6 speed, no reason I could have stalled it). The engine just cut off, I hit the key to re-start it, it spun over for about 2 seconds, started and cut off again. I let it roll into the drive way and popped the hood, nothing unusual found. Got back in to restart it and nothing, no crank-no start. The gauges slam to the left and only the VOLTS gauge seems to be working. I get NO engine check light, no Glow Plug light, I now get a "Braking System Requires Servicing" on the info display. The batteries are good. Security System works fine, radio ...... all that stuff. I get no codes from my OBD reader because it cannot communicate, so it appears the ECM is not powering up, checked all fuses, swapped relays, all the normal stuff. Pulled the left front wheel, inner fender panel to expose wiring and ECM. It all looks great, this was a well maintained truck, doubt it's ever been off road ........... I have looked at all wiring from transmission, ECM, TCM, Glow lug controller ............. at one attempt to crank the truck it did spin the engine over ..... but it was delayed by about 10 seconds, meaning I turned the key, and nothing them all by its self the starter cranked the engine for maybe 2 seconds .......which I thought was strange. I am looking for an ECM and engine diagram set for this 2006 LLY ECM?? Starter is good removed/replaced after bench checking it. Can jump the starter relay (under hood fuse/relay box) and starter will spin the engine. NOT a starter. Inspected all battery cable to start with ...... all good. Never Jump started it or anything as I have read about issues with that.
I have read about all the different places to look for wiring damage, after about 8 hours of taking things apart I have found nothing. No open fuses ....... just nothing. I traced out most of the DC grounds and cleaned/re-installed. Any help?? An ECM Pin-OUT ? TCM Pin-Out?? Engine harness diagram?...... need to look and see where I am missing Power / Ground.
Any chance one of the other controllers is killing the communications to the OBD?
Thanks in advance,
Les
Thanks in advance,
Les
