Year:2006
Make:Chevrolet
Model:Silverado 3500 HD Crew Cab
Mileage:161511 M
Transmission:Automatic
Engine:LBZ Duramax
Trim:Silverado LT
PRICE REDUCED
STOCK 2006 Silverado 3500 DRW 4WD CCLB LT STOCK
CarFax retail price $24,890
I Purchased 11/2009, Second owner
Pickup has and LT3 includes
Power windows and locks, keyless entry, Power driver and passenger front seats, Bose Audio, Leather seats, 6 CD CD changer, XM radio, Dual zone climate control
HITCHES:
Curt 2” Front receiver, B&W Turnoverball Gooseneck and goose ball, Torklift Superhitch Magnum 20K, Torklift Frame and Hitch mount slide-in camper tie downs/mounts includes removable arms, Tekonsha Prodigy P3 brake controller
INCLUDED:
B&W Companion 20k 5th wheel base (connects to B&W Turnoverball Gooseneck hitch, new driver side seat cover, foam, and heater from The Seat Shop on-line (never got around to installation), Bed mat, Chrome beauty rings for stock rims, Extra GM alternator, GM fuel and oil filter(s) (Not sure how many, at my dad’s), Banks iQ engine monitor, TYPE S backup camera
Purchased 11/2009 at 49743 miles
65649 replaced Glowplug #4
73749 replaced rear u-joint and carrier bearing
81559 replace tranny line, tranny service, drain/refill antifreeze
89147 dealer reflash ECM & TCM
92086 replace both batteries
92091 new Michelin LTX MS2 215 85R 16 tires, new spare also
109571 replace Glowplug #8
111869 replace rest of Glowplugs #1, 2, 3, 5, 6, and 7
117919 installed Monroe Gas Magnum shocks, all
118039 Front end Alignment
125514 new filter housing and sensor assy
132292 Alignment check, radiator drain/refill, tranny service
135957 replace Passenger side Alternator, see longer 136203 note
136203 replace water pump, see longer 136203 note, checked power steering OK, checked front suspension OK
143142 Power steering fluid drain/refill
146629 front end alignment - told will need suspension parts replaced, made appointment at different front end shop (six weeks out)
146976 replace Idler arm and Pitman
151015 Tranny, transfer case, F&R diffs serviced
152111 New Michelin Defender Tires 215 85R 16
153140 New Batteries Both
156953 New oil pan plug
161133 replace Glowplug #2
136203 mile and 135957 I thought there was a squeal in the passenger Alternator area. Replaced Passenger alternator (OEM). Noise remained, still thinking alternator purchased driver side alternator (OEM). I was way over due for left hip replacement so I took pickup to dealer. Turned out to be idler pulley below and to right of passenger alternator. Told dealer since that far into it, replace driver alternator, all 3 idler pulleys, tensioner, water pump and air tube.
OIL CHANGES: PURCHASED 49743
Miles: 54253, 60899, 65649, 73749, 78139, 83302, 86531, 89189, 91799, 97091, 100711, 104759, 107414, 111869, 115469, 117919, 121125, 124343, 129389, 132336, 137001, 139988, 143142, 146506, 151015, 153130, 154912, 156953, 160318 MILES. Prior owner oil changes documented in Carfax report.
FUEL FILTER CHANGES:
62963, 77869, 91799, 104759, 117919, 125514, 137001, 146506, 153130, 154912, 156953
ACCIDENTS:
Carfax reports on April 30, 2018 that an accident was reported to Carfax. This accident supposedly occurred on October 30, 2008, over ten years prior to report. October 30, 2008 is about a year prior to my purchase. I didn’t know about this until I ran the Carfax 9/10/2022. I asked my service dealer and my body shop, both thought something was amiss with the report - dealer thought “someone fat-fingered a VIN number causing it to be attached to my VIN instead of the proper vehicle. They thought report getting to Carfax a year or two late okay, but 10 years? A CarFax rep told me that all information that CarFax has is included on the CarFax report - there is NO information given. No repair shop, no damage listing, no mileage, no accident report, nothing.
On February 23, 2010 a woman hit my driver side mirror, mirror was broken because the angle it was hit the mirror couldn’t “break away”. Body shop replaced mirror and minor door . Her insurance paid.
Regarding the October 30, 2008 reported incident, I installed the front receiver, B&W gooseneck hitch and Torklift receiver hitch, tire rotations, lube jobs, going through front inner fender wells to replace fuel filters and Glowplugs, etc. I may have missed something, but I didn’t notice any over spray or metal that appeared to have any damage repair.
I have more photos I will post in subsequent posts.
Contact me with questions.
Thank you for looking,
Mark
