For those who have not seen the glow plugs, a pic is attached. To change them on the passenger side, I removed the tire, inner wheel well cover
and gained access to them. 8mm, 12mm, and a few tools to remove the body fasteners should do it.
Wheel torque 140ftlb...if you remove it.
And thanks to this pick, I found out I didn't put the positive battery cap back on.
What is that 120v plug for in the pick? Was that factory installed? Block heater? I was the 2nd owner of truck.
2017 2500 Duramax Crew Cab Long Bed
That’s because it’s a plug in hybrid.
You mean you haven’t been loading up the electrical grid for no reason? Shame on you.
I would re-cap it and store it, as mentioned. One day you may find yourself in the position of needing it. I don’t use mine often, but over the years I’ve used it now and again.
