1 - 20 of 154 Posts
Suspension Ninja
**UPDATE 9-19-11**
2011-2014 NBS -
This DIY mod was made for 2007.5-2010 NBS HD trucks, but just to confirm, this mod will be the exact same for the 2011-2014 NBS.
Important Notice! – This DIY mod instructional guide was created and intended to give the 2007.5-2014 HD truck owner the option to properly clear a specific wheel & tire combination – just as a 2001-2007 Classic body would after installing a lift kit. In many cases, NorCalTruck.com will ship out suspension packages where the wheel & tire combination has already been determined and decided on. In such cases, after this has been discussed with our client, we have suggested this mod be done. This is the reason we made this step by step DIY guide for our customers, to prepare for the proper install.
When using this DIY mod to accommodate for a larger tire and wheel combination, larger than what the manufacturer of the suspension product recommends or states is acceptable, NorCalTruck.com and/or Nor-Cal Nick (myself) is not responsible for any increased wear and/or reduced ride quality. NorCalTruck.com and/or Nor-Cal Nick will only offer Customer Service and honor the warranty for product purchased through NorCalTruck.com.
I am making this IMPORTANT NOTICE due to the increase of members suggesting to combine a Cognito 2-3" leveling package + Nor-Cal Nick Fender mod to = fitting 35x12.50 tires. THIS IS NOT recommended by Cognito Motorsports or Nor-Cal Nick.
Simple enough, please remember that just because you can make a certain tire and or wheel "FIT", it doesn’t mean it’s right. You must properly combine the suspension components to the larger tire and wheel combo to avoid issues. This DIY mod should NOT be used as a cheap fix to avoid having to purchase the components to properly set the suspension up within the correct ride height and not overwork the suspension and/or steering. We have many years of experience with these Chevy HD trucks, and see when and where the problems arise. I have personally read many emails, pm's, and have taken many calls from truck owners frustrated, chasing ride quality, and experiencing issues with excessive wear. These issues can be avoided by combining the correct products, and staying away from a tire and wheel combo too large for the suspension height.
Thank you,
Nor-Cal Nick
________________________________________
DIY Fender Mod
If you have a 2007.5-2014 Chevy/GM HD you will find it very hard to fit a good looking tire and wheel under the front fenders without rubbing the tire at full lock to lock on the cab side of the fender. Please follow these steps to adding clearance to the fender on the inside lip, no cutting on the fender where you would have to see anything in the end. After trying this on a few trucks we found that it really makes a big deference and is super clean finish.
Job takes about 2-3 hours for the first time, after 1 or 2 it goes alot faster but do not rush the job as it will pay off to be cleaner finish job when taking your time.
If you have any questions please post them. Hope this will help others.
Suspension Ninja
Discussion Starter #2
Suspension Ninja
No problem, I am glad we can offer help to the DIYers out there:drink
awesome write up man!!
i wish cali was closer...my next truck i want u to have for a month haha
I'm That Guy...
This was a great write up.
Nice write up Nick!! I did the same on my truck and it works great!!
Excellent write up Nick!
Good write up, might have to try this once they make some lifts for my truck!
another reason to support Nick/Norcal! Great writeup! I just did my passenger side this morning. I pretty much followed your directions during the process, but I made one modification at the end.
The hole on the inner metal (behind where you put the self-tappers) is perfect to accept a 6mm speednut. Then I poked just one hole through the liner and inserted a 6mm (8mm head) bolt with a fender washer on it. It worked nice and is very hidden and reusable.
:drink:drink:drink
Wally
just showed this post to my neighbor....he will be doing this saturday....thanx Nick
I was wondering what size tires you can run after this mod. My stockers are finally about to wear down and I want to run the cognito arms and level my 09 3500. I would love to run the new ultra baron 20" with + 18mm offset and a 295 55 20 nitto trail grappler ( about 32.8 x 12.5) will this work without rubbing?
1 - 20 of 154 Posts
