Status
Not open for further replies.
Hello everyone! I was looking to put my 2007 regualr cab duramax back to stock height. Due to plowing, my local dealer jacked up my torsion bars too much. Of course with my luck the dealer went out of business...measuring from the cross member bolt to the ground what is the stock height? Thank you everyone...
not sure..each truck is different....just turn them counter clock wise the exact amount and start with 1 turn..it doesnt matter where you start the ratchet just go one full revolution then do the same on the other side. then back the truck up and pull it forward and check again...if you want it lower do another turn or a half a turn and repeat backing it up and forward. should be no more than 2 turns
Status
