Been fighting this battle for sometime.
I purchased an LMM a while back for a good deal. When I test drove, I heard it make a few pops when backing out and turning right.
2008 2WD LMM CC
Rebuilt front end:
Torsion bar bushings
Moog Wheel Bearings
Delco Tie rods/Moog ends
New UCAs w/ balljoints ( new UCA pins/sliders/cams/bolts)
New LCAs w/ balljoints
New Bumpstops
Front brake job, new pads, turned rotors, cleaned calipers, greased slide pins.
New steering gear & pressure lines
New Pitman and Idler arms
New Delco Pro Sway bar links
RC Steering Stabilizer
Bilstein Yellows
New Intermediate Steering shaft( have clamp on steering column for now, but going to replace bearing soon)
New Body mounts - energy suspension, all 8.
Whats really confusing is the popping never stopped after I built the front end. Still pops when turning hard to the right, and then pops when moving back towards center.
I have some videos on youtube from under the truck. Looks like the torsion bar could be moving a little inside the new LCAs. Only happens on driver front side. Video is before the body mounts being replaced.
Fairly loud inside the cab, sometimes pops so hard I can feel it with my left foot in the floorboard.
Lived with it about 6 months. Kinda looking to fix it...took it to a tire/alignment shop. Aligns fine, they can't find any problems...so I'm turning to the internet!
Backing out of the parking lot at work turns some heads when it pops...it's occasionally that loud.
Any thoughts or suggestions?
2008 2WD LMM CC
Rebuilt front end:
Moog Wheel Bearings
New Bumpstops
Bilstein Yellows
