21 - 24 of 24 Posts
Well I should read the other messages before going on. Forget about the other checks if those other lights go off after a few seconds. D
Discussion Starter · #22 ·
You do have corrosion damage to the remote module. The last pic shows it. Also when I click on the pic a third pic shows up of a damaged wire harness, where was that at. Dean
The damaged black wire is a ground 10ga ground d wire that mounts up behind the bumper on the driver's side
Discussion Starter · #23 ·
So that theft derrent module surrounds the lock cylinder in the steering column. The code your getting is a lack of communication between that and the ecm when the key is being turned. It's not the keys because when I looked into the data on the scanner it was reading a valid key but still not sending the "start password" to the ecm..........
This is what the scanner was reading about the anti theft deterrent code
Well the good news then is there is no data buss problem. Yours is definitely within the security system, if the system sees a good key code I would likely think it may be the security module itself especially if you can reset it and it works for a bit before the problem starts up again. Never changed one of those so no idea what all needs to be done with that task. Dean
21 - 24 of 24 Posts
