hi everyone
i am experiencing this problem on my 2010 silverado 3500 6.6 the coolant level is normal when the truck is idling or off but when i start it and drive the raises above the maximum coolant mark almost reaches the cap.
i noticed that the truck is not warming up the other day i drove for 30km and still the temperature was half way warm and dropping.
i have very small leak on top of my radiator that i sealed with some jp weld but still leaks a very small amount.
could that be the problem of air getting inside?
and why the truck does not fully warm up?
appreciate any opinion.
thanks,
It's most often bad thermostats that cause an engine not to come up to operating temperature. You might stop at a radiator shop and see if they can repair your hole without taking the radiator out. Way less work for them, and less $$ for you, if they can repair in the truck.
that is what i was guessing but the fact that the coolant on the overflow tank gets more when i drive it makes me confuse.
