1 - 8 of 8 Posts
I’ve had my truck n the shop for 3 months. It’s getting good rail pressure. It cuts out & stalls for 2 or 3 seconds & goes back to normal. Sometimes it does it a lot & sometimes I can drive a few hundred miles before it does it. The shop has been tracing out wires. Fuse box, check all modules, even swap computers & different tunes. It has a kory Willis efi live 5 with fass system. It’s still doing it
If you arent working on it yourself the next step is to find a new shop. Where are you located, I might be able to help with a reputable shop
Cutting out going down the road, sometimes it doesn’t & sometimes it does it’s crazy. It ant filters or modules. I’ve seen other people on this forum have same problems but nobody ever says how they fixed it.
2011 gmc 2500 lml Duramax with Kory Willis efi live 5, has 150 fass system, stage 2 cold air intake. Have swapped modules out. Even pulled computer & put another one n it with egp tunes still cuts out at various times. Even on lowest tune setting. Was hoping someone on this forum who has same issues could tell me how they resolved this.
how are your fuel lines? any chance sucking air?
Check all the engine compartment wiring harnesses for damage caused by rubbing or chaffing, fairly common on these trucks as they age:thumbsup
Check your wiring harness that runs across the air conditioning line over the top of the engine. That harness is prone to wear at that location.
any update
Having similar issues.. any update?
1 - 8 of 8 Posts
