I need some help identifying what to call this or where i can get a replacement fuse its a very large fuse that is on the passenger side battery under a small cover. Me nor my mechanic would identify what this was called and how to find another.
Me and my mechanic installed my EGR delete, 5” Flo-pro and 3” MBRP(Bitch to install) and PPEI tunes after about a whole day ordeal dealing with stupid problems from the down pipe clamps being very small to the EGR cooler not wanting to come out in a single piece or the flo-pro exhaust not lining up to the correct hangers. Also to top it all of we made the biggest rookie mistake of not removing the positive or negative terminals form the battery thus my mechanic accidentally dropped a wrench on the alternator witch caused a nice spark and after we were finished installing cause the truck to have no dash lights or ECM response with only interior lights working we immediately took all fuse box covers off and just did the good old CHECK EVERY FUSE and ended up finding that the passenger side 175A fuse clip had tripped and cause no power to the truck any help will be great thanks!
