2015 Gmc 2500hd Denali
Fully deleted
Straight pipe
Ez link 5 switch tuner
H&S turbo top pipe
Airdog 150
Cold air intake.
187k miles
Problem started 11 months ago after a wreck and had to put a brand new frame on the truck. Truck was fine for roughly 3 months after frame swap. Then randomly the truck hesitated as if it was running out of fuel. So I changed the fuel filter. Problem was really random after that. Sometimes truck would drive fine under any conditions. Then the truck would start to hesitate (feels like running out of fuel/ fuel knock) after 70 to 80 miles. Once the problem would start for the day it would get more noticeable as the day went on and miles were driven. Thought myb a bad filter so swapped it out and problem is still there. So then thought myb the filter housing needed to be rebuilt myb a air leak. Got a kit and problem still existed. Talked with a mechanic he said rebuild kits suck to buy new oem filter housing same problem new housing wasn't the problem.
Truck spent 35 days at GM dealership they said the truck is fine and they could not get truck to act up at all. So I picked it up and 80 miles later problem shows up again. Zero codes and no check engine light comes on.
So I took it to a local diesel only truck repair shop with a great reputation in Texas. They said in testing 2 injectors were way low around -4.6 and -4.8 and two injectors were at +4.6 and +4.8
So they recommend to replace all 8 injectors so I had them put in all new stock injectors and a fuel pressure regulator with the upgraded screen that is supposed to help save fuel system in event of cp4 failure. They said truck is good to go. So I picked up the truck and noticed immediately the power is way less then normal all all 5 tunes. So I drove it about 80 miles and the hesitation problem didn't show up at all. However 45 min later I drove the truck 1 mile and let truck idle for 15 min and when driving 1 mile back home truck hesitated again same as before. So I thought myb a air bubble so I drove it for 1 week and hesitation problem wasn't a issue, however definitely a loss of power.
Then one afternoon problem stared and didn't go away at all. Next day no miles driven at all and problem shows up again and is constant now.
So I took it back to the shop and they checked injectors and they all check out cp4 is putting out 28k to 29k psi under load. Turbo is producing 28 to 30ishs psi under load. Fuel system checks out turbo checks out but problem is still there.
So the shop has even replaced ecu now and reloaded factory tune and ez link tune. The problem still exists. The problem is only around 1750 rpm to 2250 rpm once the truck shifts the problem goes away till the 1750 to 2250 rpm range till transmission shifts again. The only way to describe the problem is temporary running out of fuel/fuel knock but the truck never dies or goes into limp mode and never shoots a code.
The guys at the shop are pretty stumped as well they don't know what's going on with the truck because via computer the truck is right with no issues at all but there is a very real drive ability issue between 1750 rpm and 2250 rpm.......any ideas guys everyone is stumped on this one.
I just need my truck back asap any help is greatly appreciated Guys!
Fully deleted
Straight pipe
H&S turbo top pipe
Airdog 150
Cold air intake.
187k miles
