Have 4300k kit with 55 watt ballasts from them and loving it too! Top notch product. I also put 4300k HIDs in the fogs, currently have 35 watt ballasts, but about to move down to 25 from another distributor just because they don't make them.
Thanks. Good info! Why 50watt ballasts over 35watt? More light?Ive got the morimoto projectors, morimoto xb-35 4300k bulbs, morimoto 50 watt ballasts, and their hd relay headed towards me i hope. I ordered it all monday night last week, so today makes 7 days
Guess they are low on stock as everything i read said they normally had super quick shipping.
The reason we go with 4300k is because its the most efficient temp for an hid. Will look pretty much factory, with a heck of alot more light. 5k are ok to if u like a hint of blue, with a little less lumens then a 4300k
Sweet! If you purchase the Sierra Spec kit it comes with everything. Harness and all, plug and play!nice, I just installed mine Friday night (ordered the kit on Black Friday). I didnt order the HD Relay harness (not sure why it doesnt just come with the kit, and have the canbus be an add on) but it works fine without it(ill order it eventually, but is not needed to work. May decrease the lifespan of my ballasts, but oh well). After removing the airbox it installs nice and easy.
ONE THING TO NOTE. the plugs that go to the factory headlight harness can plug in either way (for polarity). if you get it all hooked up and one of the headlights (or both) doesnt turn on, flip that plug around. I messed around with the ballasts and plugs and everything for 20 minutes before I realized they were two way plugs. I was getting frustrated hahaha
4300k has a higher Lumen count then 5000k. The lower you go on the spectrum the higher the lumen count. Now the higher in kelvin you go the more color will come. A 5k will be slightly blue/white then a 4300. For me the 5k best matched the factory LED's and I like the whiter light for winter conditions.Thanks. Good info! Why 50watt ballasts over 35watt? More light?
If you are going to run HID's in your fogs stay with a 25w, the higher wattage kits will burn your reflectors and lenses. The bulb is a 5202.Forgive this ignorant question.
Is the different between 4300 and 5k just light spectrum/color? Why did you guys chose 4300 over the 5k?
Info for fog light upgrade would be appreciated.
9006: Morimoto Elite HID System - HID Systems from The Retrofit Source IncSweet! If you purchase the Sierra Spec kit it comes with everything. Harness and all, plug and play!
Also the 55W are known to melt housings because of the heat output. I did 35W 5k bulbs, and then got the VLED LED fog lights (which do nothing for light output, but match the color of the DRL's.4300k has a higher Lumen count then 5000k. The lower you go on the spectrum the higher the lumen count. Now the higher in kelvin you go the more color will come. A 5k will be slightly blue/white then a 4300. For me the 5k best matched the factory LED's and I like the whiter light for winter conditions.
The 55W with produce more light output but with a shorter lifespan. Also as you go up in Watts the color spectrum will change. In my experience a 35w 5k would be similar in color as a 6k 55w.
