90K you're lucky. Many LML's leaked before that mileage and some right after they were bought with low mileage. GM in the factory must not have either prepped the surface good enough or didn't allow the sealant to cure long enough. I believe the instructions recommend 12 to 24 hrs to cure.
I had a shop replace mine with a Bananna Pan which is similar to the PPE at about 60K. The shop used the GM sealant and no gaskit. I believe but not sure the shop fully torqued the bolts to what they should be after it cured.
