1 - 2 of 2 Posts
Looking at installing some new wheels from DDC on my 2016 Denali DRW. They designed a wheel that looks like a 10 bolt wheel, but is a direct bolt on. My truck is 100% stock right now far as wheels or leveling. Trying to decide what size tire I should go with. 275/55r20 or 275/60r20. I still tow often with the truck so don't wanna go much larger than stock and affect gear ratio and shift patterns. Tire size calculator shows the 275/55r20 basically the same diameter as my stock tires. Just looking for some suggestions here from people that have already done this. Thanks!
I ran a 275/65/20 on a 10 lug 20” wheel with adapters at stock height. You’ll be fine with either of those sizes, since you’ll have more positive offset with DBOs than I did
1 - 2 of 2 Posts
