1 - 10 of 10 Posts
I am new to this HD family. I am leveling out my 2500, installing 35 nittos, and I am in want of good wheel selections that do not stick out much from stock.
I don’t know what to look for. Thanks in advance!
2021 Denali HD Fabtech Lift and 37s
Stay in the 20x9 or 20x10 range for wheels and I’d suggest sticking to -20 offset to keep the wheels from poking out too much. A 0 to positive offset will help keep them tucked more.
I appreciate the response. Links to any wheels? Having a hard time finding options.
I had good luck with rimzone. Showed up on my doorstep ready to bolt up. and x2 with the 9 or 10" wheel to keep them reasonably in line with the truck.
As mentioned above go to the custom offsets site gallery. You can search by vehicle, wheel or wheel and tire size combo.
2020 GMC Sierra 3500 HD Denali
wrong!!!!
a -20 offset will make the wheels stick way out. you want a +20 to keep them tucked in. 0 is the least I would run if you want them to not be out too far. I run a 0 and it is marginally acceptable.
2021 Denali HD
wrong!!!!
👆this
I fully understand offset and I know -20 pokes out more and +20 tucks. The OP said he didn’t want them to poke out too much. That’s why I said -20 or less meaning heading back towards positive numbers. I run -1 offset in the winter and -40 offset in the summer and see everyday the difference in poke. Glad we got that all cleared up.
2021 Denali HD
-20 on a 20x10 will not work with a leveling kit. I was not questioning your knowledge of offsets, just the op is leveling his truck, and if he got a -20 offset, he’s in for a world of trimming and headaches.
On a level only, best to stay in the + range of offsets, with the 35” tire he plans on running.
1 - 10 of 10 Posts
