21 - 40 of 262 Posts
Discussion Starter #22
Here is mine.....waiting on cab lights and harness to become available so I can install those (anyone have any info on that yet?). Also going to try and figure out which pins in the BCM control the rear-facing lights in the mirrors and the reverse lights so I can run a jumper diode so the mirror lights activate when in reverse. Window tint and ceramic coat getting done this week. Also ordered black "AT4 HD" emblems for the doors. Only driven 40 miles so far.... seems much improved from my 16
Where did you order the black AT4 HD emblems from? I have put on the black GMC emblems front & rear, but getting rid of the other chrome bits would be nice too.
Also - are the 35x12.5 tires rubbing anywhere? I can't tell if you are still stock height or not in the front.
As for the diode jumper, I did this same thin on my 18 though I eventually removed it. The mirror lights got annoying, to me at least.
On my 2020, I added the diode jumper from 10 to 18 on the brown plug so that my fog lights will work with my high beams. It works flawlessly, is easily removed without any damage, and works with Intellibeam.
I ordered the black AT4's from Ebay (pack of 3 that are black w/ a red 4). Then I ordered the 2500 HD black emblems. I will use the black AT4 and only the HD portion of the other. They don't have the actual complete AT4 HD emblems available yet. Not sure exactly how this will look, but gonna find out :)
Tires do not rub at all..... I did turn the bars up only 3 turns to level with the back, but the tires didn't rub either way.
I really liked my lights coming on on reverse.... helped so much at night
I'd be interested to see pictures of the light bar when you have a chance.
Also, are you planning to do anything to accommodate the 295/65 tires? Or do you think they'll fit without any issues in the front? I would also like to go larger but didn't plan to put on different wheels to change spacing. I had 285/65s on my 2018 with keys turned and +20 wheels. Hadn't really considered going much larger until seeing your post.
Thanks.
I will get a picture in time.
I am not planning to do any mods for the tires, going to run stock wheels as well. Should be fine, another on this thread is running 35/12.5-20 on +20 and said they clear even before bar crank.
295/65-20 measures same as 35/12.5-20, but much higher load 4080# vs 3195# or 129/126R E vs 121R E which matters to me as I will be working the truck not cruising the mall......lol
Ordered mine 6/27 built 8/7 delivered 8/29
295/65-20 Michelin Defenders ordered today
Installed Putco Blade light bar this weekend
One thing i have noticed, 550mi currently have not had my first regen.
My '18 driving locally would regen every 150-250mi.
Apparently there is a new logic applied to regeneration.
Have my Banks Idash installed and will again be a Banks test pilot for the Derringer when it is ready
I have not noticed a "regen" as of yet, it seems like the elevated idle is not happening which was one of the key indicators on my 2019. I'm at 2200 miles, and my DEF gauge has depleted around 40% since I drove it off the lot. However I've thought several times that the brakes seemed to be stiffer than normal when coming to a stop, made me wonder if the truck was regening when that happens. But like I said, no other indications.
Thanks.
Lol... i dont do malls. Actually my 35’s are on 18” wheels and have a load capacity of 3970 🙂
Not that you can really tell, but the pic I posted with my 2002 backed up next to the 2020 is a Chevy LTZ. I was trying to capture the height difference from my old one so I wasn't worried about getting the rest of the truck in the picture.
I like the lines better on the Chevys but I HATE the grills (except for the High Country).
LT,
My truck has the front end raised 1.5" with 2" blocks on the back and am running 35's. Rough measurement the top of the bed of my truck is just about even with the top of the bed of the new ones. I roughly measured a friends '18 3500 and his is taller by 1/2-1" if my rough measurements are accurate.
I saw a white LTZ, ugliest thing I ever saw. Then saw a Cajun Red LTZ and that looked a lot better. That is why I'm anxiously waiting to see a black one.
Now the GMC dealer down the road from the Chevy dealer had about 10 new trucks in Denali, AT4 and SLT trim. I'm still on the fence about which truck to purchase....
LT,
I'm running 265s rather than the 245s that were stock but all else is stock. So, I might be 1/2" higher or less than stock.
I like the Denali best I think. I also really like the Swiss Army tailgate but if I end up going that way, I will re-wire the tailgate with a switch in the trailer receiver that keeps the top part of the tailgate from opening if there's a hitch in the receiver. Should be really simple to do. Not sure why GMC didn't do that.
Please do a post on that.
See this thread that McGraff started. I put a more complete description of what I'm talking about in post #2. If desired, I can draw out how the circuit should work but I do not really have ANY info at this moment on how that section of the tailgate operates (electrically? mechanically? wiring?) so it's mostly just speculation on my part at this point. But if it works the way I think it does, there should be no problem at all putting a "safety switch" in the circuit so that that part of the tailgate cannot open if there's a draw bar in the receiver.
https://www.duramaxforum.com/forum/2017-up-non-powertrain/999647-2020-hd-multipro-tailgate-hitch-ball-solution.html
Here’s mine. Trying to figure out what wheel and tire combo I want to run. Leaning towards putting a set of 35X11.50 Nitto Ridge Grappler’s on the stock wheels. I threw a 35X12.50 with 22X10 -25 offset American Force combo on the front and it looked great but require some major trimming of plastic even with a few turns on the torsion bars.
that is one sweet looking ride !!
Thank u
So you don’t like the 2020 GMC? I actually have a 18 to and wouldn’t trade it for the world but think GMC headed in the right direction with the new larger truck. I personally like the smaller size of my truck but know GM is behind in sales due to the lower stance and smaller dimensions etc. Most buyers want biggest and baddest but I got tired of not being able to use drive thru’s and having to park in No-Mans land. Now Chevy, not sure what the front end designer were smoking but that’s one ugly truck ... lol
I actually like the body lines on the 2020 Chevys better than the lines of the GMC (cleaner), However, everything but the High Country has that atrocious grill and that's just NOT gonna happen for me. I also like the tailgate on the GMC enough to sway the decision over to GMC over the High Country.
LT,
I'm leaning the same way you are...in my opinion, how the front end of the Chevy looks is totally dependent on the color of the truck. In Cajun red it doesn't look bad, in white I can not stand it, waiting to see a black one, that should make my final decision.
There are several major differences from the HC grill to the rest...I like the HC grill but I am old school and I like chrome...so the HC is out for me. I looked at the opportunity to swap an HC grill onto a LTZ, but there are way too many difference to allow that...at least in my preliminary investigation
-Mark
