2021 GMC 6.6L Duramax 2500HD Trany Issues
1 reading
45K views 45 replies 21 participants last post by  blythkd1
It's the nature of the Ford 10spd "Allison branded in Name Only" transmission. TFLTrucks noted that the L5P went from the best mileage of the big three in 2019 to the worst MPG in the 2020 model year. The only change was replacing the 6spd Allison with the 10spd 10L1000 Ford trans.
Too bad to. Allison had a 9spd set to go into the 2020 model year...
It's the same trans as far as function and size but they are not interchangeable for brand identity and they do have different torque converters
Where's the cut-away pic of the GM 10 speed? Why does the Ford specs identify 18qt capacity but the GM version has the fluid capacity missing? Why is the weight of the GM missing?
Hopefully Mike L. will chime in with his expertise since I am paraphrasing his post from another forum...
