Thanks Satar, I appreciate all the good information.Yep from your photo I understand your concern. They have that pin box tucked under there pretty good. Mine extends out a few inch's. Looked on my phone and don't have a good pic of it but found this website pic that shows the difference. I'm with you, either wait for the truck or order a slider.
The Demco or Pullrite brands are the best out there for auto sliders. There are a few guys on here that can speak to one or the other. The nice thing about the Demco is the capture bars are built into the head of the hitch so when you disconnect your fifth wheel pin box looks just like any other. The the Pullrite you have to mount a "capture plate" onto your pin box, mind you the newer capture plates go on and off relatively easily. I point out these two differences because if your truck ever breaks down and you need it towed and your camper towed there is a high probability that whoever tows your camper will have a standard fifth wheel and being able to restore it to standard simply is essential.
If you decide on a slider personally I would highly recommend an auto slider like the pullrite or demco. No one wants to worry about that tight fuel station, or should I hold up traffic to slide or not, it takes care of itself. I towed with pullrite auto slide for 12 years and it was solid. Only downside I can think of and simple repositioning usually takes care of it is the truck can't be at too sharp of an angle to disconnect. If repositioning is not an option to straighten the truck out a bit then you can unpin the head and lift it off, had this happen once in 12 years.
here's another thread with some good info building also.
(8) 5th wheels for dummies | Chevy and GMC Duramax Diesel Forum (duramaxforum.com)
My 07 2500 cummins short bed was bad with the chucking/nose bobbing, I started running with a full tank of water and it helped quite a bit, eased some of the pressure off the pin.I seemed to have excessive chucking with the short bed. I replaced the pin box with a MoRryde cushioned pin box which reduced chucking. BTW, I have a Reese 20k slider and haven't had to use it yet.
Replying without reading ahead.Howdy,
Help please.
Just purchased a 23 3500HD crew SRW with standard 6'9" bed w/ factory puck system.
Looking at B&W companion 20k 5er hitch. I was going to get slider but B&W said with new truck slider is not needed. Puck system already sits further back than previous gen trucks. I asked, so NO cab clearance issues if I get a non-slider RVK3710 and she said yes.
Anyone out there have this set up and confirm it's good to go?
TIA
OrcuttHD FWIW the best 5th hitch is none in ocer 30yrs RVing I'm on 3rd 5ver on 2nd D'max and 2nd Reese Pinbox 1st was 5th Airborne with Sidewinder on Anderson Ultimate in SB Silverado CCDA. Current on My '15 Sierra SLT 3500 4x4 DCDA DRW I ordered in 4'14 is Reese Goose box 4/20k# on 18k# Fuzion 375 just have 2 5/16" ball in bed no back ache to remove and 5" travel of air to save the trailer on deferred maintenance hwys and fire roads. Happy Camping
I towed 4 years with a 2017 3500 standard bed with B&W turnover ball. Although not identical to your puck system, close enough I think. I could easily get about 70 degrees of turn which was good enough for any campground including State parks. Yes, sometimes had to pull up and back a few times but so what. I've since bought a 2022 3500 with factory gooseneck prep, and use a Goosebox on my 5er. Night and day difference and could, I repeat could get 90 degrees now but I still don't ever go much past 70 degrees.Howdy,
Help please.
TIA
Have this exact setup as of this week. No clearance issues. Made a u-turn in my storage lot that I normally couldn’t do with my 2019 and rail setup, and that one never had an issue. Have it set it the most rearward position.Howdy,
Help please.
TIA
Excellent, thank you!Have this exact setup as of this week. No clearance issues. Made a u-turn in my storage lot that I normally couldn’t do with my 2019 and rail setup, and that one never had an issue. Have it set it the most rearward position.
Sent from my iPhone using Tapatalk![]()
I had to set it at the lowest height. I first set it up at mid height because that’s where I had the B&W Patriot 16K on my 2019. This bed must be more shallow as I had to lower it. Still 7” clearance. The base is actually not very heavy at all. I’ll probably pull this one out when we don’t tow for extended periods. You’ll like it.Excellent, thank you!
Got my new truck last night.
Ordering hitch today.
What height did you go with?
Thank you!
My 3500 definitely sits ass up unloaded.I’ll be curious to here what others say, but all these trucks are nearly level, so any load will drop it a little in the bag. Also, even a few inches is some serious lever when talking about 2000lbs. I think. Trying to recall physics from years ago.
Mine is a 2500 with Timbrens and you can see a slight sag in the rear here too. Hitch is setup like yours. I thought about moving it forward.
