got an 02 d-max and was looking at some 285/70/17's and was wondering if these will fit without touching the t-bars. i REALLY dont wanna have to adjust t-bars unless i HAVE to. tell me what you think.
I believe you will have to crank your torsions a little. You might be able to get away with some trimming and ziptieing. It all depends on how your stock settings were. Each truck is different and it depends on what rims/backspacing you are using.
Diesel Addict
won't work unless you bump the T/Bars up a little..
Your amount of turns might depend a little bit on mileage and wear. But you are for sure going to have to touch them and trim the lower facia piece. If you don't want to raise the t bars then I would suggest going with a 265.
