Who's running a 295/55/20 tire? Can't decide what wheel to go with. I've had 20x9 0 offset with 285/55/20 tires. I'd like a little bit wider tire. I'm thinking going with the same size of wheel and offset would still work with that 295. I don't want them hanging outside the fender a whole lot, a little bit is fine but also I don't want them tucked way inside either. Maybe a +18 offset? If you have pictures, post them up!
Supporting Vendor
A 295/55/20 would certainly work on the 20x9. If you went with a +18 rather than the 0 offset, you could anticipate the wheel would be tucked in about 3/4" however by going to the wider 295 the tire would be 3/8" back out, so it would sit about where it does now. So the +18 would accomplish the goal, or you could even run a 305/55 with the +18. This would pull the wheel in 3/4" and the tire back out about 3/4" basically giving you a wider tire and likely not affecting the stance.
