From the manual...
Priming the Fuel System
There is an electric priming pump that will
bring fuel to the engine and eliminate air in
the fuel lines. To prime the engine:
1. Correct any condition that caused the
loss of prime.
2. Turn the ignition on for 30 seconds. Do
not start the engine. The fuel pump will
start priming.
3. Turn the ignition off, then back on, and
crank the engine for 15 seconds.
4. If the engine does not start, repeat
Steps 2 and 3 until the engine starts.
If the engine does not start after
repeating Steps 2 and 3 three times, turn
the ignition off for 60 seconds.
5. Repeat the above steps until the engine
starts.
6. If the engine starts, but does not run
smoothly, increase the engine speed
slightly.
7. If the engine starts and runs but stalls
again, turn the ignition off for
60 seconds.
8. When the engine starts, let it idle for a
few minutes and check the filter for any
leaks.
