1 - 8 of 8 Posts
So I just got my 3.5in rough country lift installed on my 2012 Chevy 2500HD. I know this is a cheap lift and isn’t the best ride quality but my question is how can I make it a little bit smoother? Some people say they love the lift and it rides so good and mine just isn’t that it’s extremely rough on bumps and really bouncy almost to the point where I don’t want to drive it. Does it need time to break in or could I have done something wrong? I’m new to the truck scene any help would be appreciated.
3.5" of "lift" this kit claims with the parts that are offered will do nothing but make you feel like you're riding a mule. Unfortunately that's just part of sticking to the cheaper option of "lifting" the truck that is basically a glorified leveling kit. Your best bet for what you have now is to remove the rear blocks the kit came with and lower the front end by backing out the bolt on the keys. That's about as good as you're going to get besides maybe front diff spacers that prolly wont make too much of a difference. If you're concerned about ride quality your best bet is to either use a drop shackle in the rear to level and keep the front end as close to stock as possible or buy a true 4-6" lift kit and de-crank it and don't use the rear blocks if you want the height of the rough country kit. What tire size/wheel offset are you running?
Totally understand that it’s a cheap way to lift the truck but I’ve had trucks just leveled on some bigger blocks and rode wayyy smoother than this. If I got better shock absorbers would that help? And I have 20in fuel Mavericks with 35’s 12in wide
The shocks will help a little depending on what you get but honestly its the angles of the front end that are making ir ride the way it is. If you dont change those angles the ride will continue to suffer.
The biggest thing is your CV angles. Search on here or google about CV Angles. Ideally they should be flat. Only way that will happen is if you buy and actual lift kit. A leveling kit will never have flat CV angles.
Had the same Tuff Country 3.5“ kit on my 2019 High Country with 35’s for about six months. Hated it. Horribly stiff ride, was hell on my tie rods (due to steep angles), hard on my lower ball joints (steep angles), hard on my CV joints (steep angles but I did the diff drop spacers to slightly reduce the angles), put in Bilstein shocks, even lost an upper ball joint within a few months that Tuff Country replaced. Did everything I could to try and make that kit work. Finally took it out and put a FabTech 4 inch suspension lift in. What a difference. My truck actually rides better than stock. Sorry to share my experience with the same kit. My advise, put in a true suspension lift kit.
1 - 8 of 8 Posts
