1 - 16 of 16 Posts
Now i have read several forums on guys asking which size of the two tire sizes to get...i have had 2 sets of 285s and they seem to be perfect but i wanna go bigger (of coarse) so what do you guys think? pics of 305s? i plan on using the factory rims for now.....but rims are always an option...also would a leveling kit/ blocks be necessary? SOME trimming is also ok but i dont wanna hack off half my front bumber....thanks guys :drink
Received a Hummer
First off...I def. wouldn't put 305's on stock wheels.....just for safety reasons. You are going from an 11.2 inch width to a 12 inch width, which at full turn will more than likely rub a bit on the back of the wheel well. If you got aftermarket wheels and a leveling kit, you could fit them with minor trimming, but you would need to get the correct offset. I would suggest calling Discount Tire Direct and seeing what they can do for you.
Found this thread, and for those of you that think that 285's-305's can safely be mounted on stock rims need to read. The factory rim is only 6.5" wide, and there is not 1 tire manufacture out there that recommends a 285 or 305 tire on that narrow of a rim. I just hope family is not riding next to you guys when they do eventually fail:cool:
http://www.duramaxforum.com/forum/wheels-tires/8583-danger-big-tires-oem-wheels.html
I run BFG 305's on my stock wheels without any problems. You have to trim some plastic and raise the bars some for 285's and 305's. I like the width of the 305 better and when I get some wheels they fill out the wheels nicely. I have 17" factory wheels.
How wide of a tire on H2s?
ya i know what you mean about the 6.5 inch rim thats the only real hold back on getting 305s......as for the H2s my buddy has 315s on a 1500HD with bars cranked very minor rubbing....i was also considering that option too but idk if i like the h2 rim THAT much plus buying tires for a 17" rim blows
Here is an older pic of mine with 305's. I have no rubbing issues at all. These are 16" wheels BTW.
Also the front bumper is trimmed. I can get pictures of this if needed. Without the bumper being trimmed the wheels would hit.
haha i know i hear ya im really considering the H2s anyone got any pics? im thinking of painting the black and getting the NBS chrome centers....
Quicker Then Brian!
305s and 285s are the same size exactly the 305's are just a little wider. I don't care what anyone says I've run 315's on the stock rims and never had a problem. If anything the truck was more stable. Amd I beat on my truck trust me
305s and 285ss are NOT the same size. Tire sizes are calculated as such: the 3 digit number mostly talked about (265, 285, 305, etc) is the width of the tire in millimeters. The 2 digit number (75, 65, 50, etc) is the ratio of the width of the tire to the sidewall height. For instance a 285/75R16 is a tire with a 285mm width and the sidewall height is 75% of the width or about 214mm. Of course the last 2 numbers are the rim size in diameter.
Quicker Then Brian!
285/75/16 and 305/70/16 are EXACTLY the same HEIGHT
That's not what you said in this post. You said nothing about the ratio (70 vs 75)
Former GM Tech and parts
Here's a pic of my H2s with 33x12.50s. I had 285/16s before, and I don't rub at all. Minor trimming of plastic, already done with the 285s
Discussion Starter · #16 ·
thats perfect exactly what i want my truck to look like... i know most H2s you can find on craigslist with 315s and i know with some trimming those will fit...they come out to be 34.4 x 12.4 so thats pretty cool with me haha
1 - 16 of 16 Posts
