1 - 20 of 20 Posts
hey guys im new to the whole lifted truck, diesel scene.
i was curious if i could clear 35's with a little cutting and grinding? i have a 02 duramax 2500hd. i currently have 285 75 16's on there right now.
i was also curious how much lift would i need to clear 37" tires? sry for the newb questions.
Diesel Addict
well with the 37" tires you will need atleast a 6" lift,you can fit a 35" tire with a 2" lift if you wanted to....hope this helps
ps have you decided what tires you are going with,and are you buying aftermarket wheels?
If you want 35's you will have to go with 6" lift. Fords can fit 37's/6".
If you go bigger than 6" i think you have to change out you drive shafts
I know its a whole different setup but Im clearing 35x13.50 tires with a 5.5'' lift on my 96 chev 1500
you cant fit 35s with a leveling kit. i have a pro comp 2.5in leveling kit and i can clear
33s fine. you need a 6in lift to clear 35s with no trimming
Actually a lot of people clear 35's by just cranking the bars all the way up. I run 33's stock with out any cranking whatsoever and no rubbing either.
do you have any more pictures of your truck with 35's and just the readylift keys i have the same set up and want to run 35 inch tires. how much did you have to trim and is there any rubbing on the upper control arms or e brake cables or anything like that?
Jank-A-Lank
35's with stock keys maxed out, putting on cognito UCAs and new torsion keys cause mine are worn.
trimmed and cut. but i think it fills out the fenders better than any other combo.
Jank-A-Lank
Damn.
These trucks are clean.
Subscribing.
I'm guessing you can do the same on a dually??
Hmm
May be going this route for the next set of tires.
yessir my buddy is running 35s on his 05, he has them on 16s though, looks pretty sick. best picture i got.
with the right offset and backspacing you can clear 35s if youre cranked and trimmed, on a 6" lift youll clear 35s with ease and can crank the bars hard and trim to clear 37s, better off doing an 8" if you want the 37"s though
Doin it...
35s with just ready lift keys
Can you also show some pics of where and how you trimmed possibly. Also pm me real quick so we can talk. Thanks
I run 35's on just keys and just trimmed the black plastic inner fender, I dont run any mud flaps on the front, doesn't look like anyone does, going down to 33's for winter cause i have them from my old truck, I am gonnna do a 7inch bds kit one of these days with the keys and rear 2 inch blocks i am told I should be able to clear 37's maybe 38's
how are your cv angles? and how is the ride?
is anyone running 35 inch tires with a leveling kit on a 2001?
cv angles are not great and neither is the ride i have the shock extensions in but it still seems more rigid.
1 - 20 of 20 Posts
