ok guys, beater truck 1991 2500 chevy pickup 350 tbi. When idling at a stop light the truck wants to die and runs like it has a cam in it, other than that runs like a champ. No check engine lights, new plugs wires dist. cap and rotor, checked for vacuum leak, checked egr seems to be fine. new idle air control valve (old one would not move). swapped out map sensor on diff. truck that runs fine and did not change the way it ran. The injectors seem to be fine as i checked those also, ran a can of sea foam through it hoping for good luck. also recently replaced is fuel filter and pcv valve. ANY ideas:help i am at a loss. may be forgetting something else i replaced....:help
