1 - 10 of 10 Posts
Stupid Has The Balls
Got One Thanks Guys
I just put a 4" Magnaflow cat into my MBRP straight pipe. I was told it would eliminate the vvt hiss, make the tone a little quieter, I would be able to pass emissions no problem and not sacrifice the power of the straight pipe . If this were the case it would be well worth the $260 I paid for it. It seems a little restrictive and the hiss is still very noticeable. If you need a cat in there for emissions you could clamp one in and have a straight pipe to clamp back in place afterwards right? Maybe have some pipe welded to the stock one to make that work if you still have it. I would not recommend the Magnaflow unless you need to have it on there permanently, it is much smaller and less restrictive then the stock one. It is not the proper solution for my problem though.
I need one to stay in full time and I already have the cat delete pipe in. I'm in CT and I travel a lot to NY, RI and MA, all of which are stringent when it comes to checking. My buddy got pulled over without one, $10,000 fine and the vehicle had to be parked and he had to find a ride home, get the truck towed and buy a cat. I'm trying to save the hassle of that
How long is your cat delete pipe? Is it 4" inner diameter on both ends?
4 inch I.D. all the way through to the tail pipe, but there is a perfect spot to cut a piece of the cat delete out and weld the cat in. Its right between the two tranny cross members since the pipe is perfectly straight there.
I put mine as close to the engine as possible. Pretty much were the stock one was mounted. Alligator has the cat for $257 shipped.
Yeah I think you may be the only one on here with one. No one else will. I'll have to go with them
Banned
If it were me Id cut the pipe and put the cat in with some stainless band clamps so you could remove it if you want to. Unless you like a cat? I dont :rolleyes:
That is what I did to swap it in and out.
I know this is a older post, but if anybody needs a Duramax Cat my buddy has one available.....
1 - 10 of 10 Posts
