1 - 10 of 10 Posts
Getting ready to put a lift on my truck, wanting to go 4" and run around a 35" tire. Now should I go stright 4" or get the 6" and back the torsion bars down. Thanks for all the input!
What lift are you looking into? A 4-6" Cognito is good for 33x11.50 with no trimming, or 35x12.50 set at 4" with the "Fender Mod". You can also set the 4-6" package at 6" and clear a 35x12.50 with no fender mod. A Cognito 6"-9" package will clear from 35x12.50 to 37x17.50 depending where its set.
I've been looking at zone lifts, but i wasnt sure which brand lifts i can drop
What is needed to run 33's or 35's on a '15 3500 SRW?
X2 for zone. You can run it low with 3" blocks with 33's and have negative cv angles. Launches well in 4x4. Or you can run 4" block with 35's or 5" block and some guys have cleared 37's (offset of wheels will be factor)
3" block 33's 20x10 -24
4" block on 35's
4" block on 35's
I dig the 35" look and that probably what I'm going to go with. Will the shocks in the 6" kit work or do I need to buy shorter ones. Also o will probably machine the 6" blocks down, can you get me the specs on yours?
1 - 10 of 10 Posts
