Hi all! New member here. I have a 2015 with 415k on it. I’ve had super luck with the truck overall, but alas I figured it had a blown head gasket when I was putting a gallon of coolant in at every fuel stop…
I found a diesel performance shop where I live in Ocala, FL. As I suspected they told me the head gasket was blown. Compression test was good, one cylinder was a little low but they suspected that was due to the head gasket.
I told them I wanted ARP head studs, due to the high mileage they would have thy head machined, etc. On my quote for the head gasket was also: engine water pump, thermostat (there was 2 different ones listed on quote?), and glow plugs.
He asked me about a few things:
1. Replacing all injectors. Injectors have never been replaced, so he recommended I replace all 8. I asked about doing a slightly bigger injector (30%) vs stock. They chose the S&S Diesel 30% injectors or just replace with Bosch reman injectors.
2. converting the CP4 to a CP3. Good idea? My dad has a Ram with the failed CP4, so I assume yes and I know if the CP4 fails that is a whole new fuel system… $$$$$
They chose the Fleece Performance conversion kit. Is this a good idea because I have over 400k even with my FASS?
While they have the truck, they are also doing the AC Actuator, as I have lived in Florida with virtually no AC on the drivers side for 2 years…
Some background, the truck was deleted and tuned around 150k, with a FASS, EFI Live. Transmission is stock. First major problem with the truck was around 230k when my alternator blew up and shredded the serpentine belt. Other than that, the truck has been wonderful and I hope to get many more miles out of it. I transport horses for a living, so most of my miles are highway miles.
Anything else I should consider getting done? This is a beautiful truck and looks immaculate and drives fantastic, especially considering the miles.
