I have a question for you guys. 2002 lb7 just put 30% over injectors, resurfaced head, port and polish, ARP studs, fass 220gph lift pump and cometic MLS gaskets on. Could not get it to prime or build much pressure at the rails. I can see what looks like fuel dripping out of the head during cranking on the pass. Side right above the starter. First question if the gasket did not seal properly and I have to put new in will I need new arps. I have pre stretched they as instructions just wondering if they would cause an issue if reused. Second question is what could have cause they gasket not to seal. I don't think it could have moved at all during installation but I don't know. Any ideas on how I could reseal it if at all possible thanks
