1 - 1 of 1 Posts
Were Im at its bene over 100 for the last 3 months & noticed the oil pressure in the truck has bene a little on the low side,20-25 at idle,38-45 on the road.The heat just broke & now were in the low 60's-70.Sure made a difference with the oil pressure.25-30 idle,40-50 on the road.I cant imagine how thin the oil must have bene when it was 104 outside.I was reading some forums about the guys noticing different readings from day to day.The hotter the lower,the colder the higher.I noticed when it is hot out mine has more power then when its cooler.I know a deisel is made for hotter conditions.Makes ya sure watch the guages when it gets hot out.Never know if somethings going out or not with them low readings.Since I had about 125,000 on it I have lost about 5-10 lbs. oil pressure.She's gittin loser now & I noticed to it has more power then when it did'nt have over 100,000.I hope the rest of you have as much luck with your trucks as I have.Very few problems here.
1 - 1 of 1 Posts
