1 - 9 of 9 Posts
I've been playing the remove and replace game on my LMM. My cruise control isn't working and I'm throwing a brake switch code, I just installed a new brake switch, same thing. Everytime I turn left the bad light freaks out, I replaced both front hubs that helped for about two weeks now it's back. Any help?
If it comes on when you turn, it's more than likely a Steering Angle Sensor problem. My LMM has the same problem. I've just been procrastinating the install. Is the message saying Service Stabilitrak?
No I don't think I have stabilitrack it's just the abs light on the speedo side
Only when I turn left or hit a hard bump. Also when I'm cruising down the highway
My LML is doing the same thing. Its showing service trailer brake message in the DIC and the cruise is not working. It starting doing this after I installed all my mods. Got Kory to check everything and found out everything was good on his end so I'm guessing this is my problem also. The brake switch you referenced can you tell me where its located, and where i can get a replacement?? Thanks
It's right on the brake pedal. You can get one from the dealer they're like $30. Mine wasn't the brake switch it's something else.
1 - 9 of 9 Posts
