When slowing down to almost stop ,abs light comes on sometimes and truck pulls to the right as comming to a stop.Does anyone know if the problem would be the right side or the left? Thanks for any replies.
Administrator
Get the code read with a scanner that most any autoparts store will have. It will tell u which one is bad. You can also jack up the front end and try to rock the tire at 12 and 6 o'clock. If it moves, it (hub/wheel bearing) is bad.
Appreciate it.
