When I turn my AC on the passenger side works fine, but the driver's side only blows hot air, even when set at 60 degrees. Any ideas? A buddy of mine has an 05 duramax and he told me his just started having the same problem.
Hi Hoseman,
I have the same problem as you, started today. But, mine is opposite, cool on drivers side, hot on passenger. I hope someone on this forum has some suggestions. If I find something I'll pm you. This is not going to go with the wife!
Mine once with ac on was blowing hot air, so i shut it off an drove with the windows down. Had to make a stop an shut truck off, got back in an turned ac on, haven't had a problem since.
Well, I tried the trick were you pull the HVAC/ECAS fuse under the hood. It did not work right away but after a few engine restarts and the next day I had a working system. Maybe it has to go through a few on/off cycles? Odd.
