I ordered a mini maxx tuner and 5" Flo pro turbo back exhaust. Says it comes with dpf delete pipe.
Now here is where I have questions and confusion. Still trying To learn everything.
Dpf delete pipe and down pipe 2 different pipes?? and if so I'm assuming I need to order a delete pipe? I got a little confused on that part.
Egr delete kit- I will need to purchase an up pipe with this correct? Now it also says I can buy a DRP downpipe, is this the passenger side cooler tube and is it really needed?
Final question. I was thinking about buying the Fass 150 lift pump, is it really needed and neccassary to have? I will be running the mini maxx on the tow (mild) 75% of the time and the other 25% on street (hot) rarely changing it to wild as it is my daily driver and not to concerned about having it on extra 150hp much.
Pretty much I want to take as much stress off the transmission and reduce the heat as much as possible without spending the money on manifolds or a new transmission. I also plan on buying the transmission tune from H&S to help out the shift points
I just need a list of the things I'm suppose to have to do the full deletes and double check to make sure I'm understanding it right.
Thanks for your help
