I have had a "check airbag" light on for awhile now. While working on other stuff I figured I would see if I could find the sensor. I had it plugged into a scanner at one point and I thought it said right front airbag sensor, but I can only find one sensor in the middle above the plastic splash shield. Is that the one I should be looking for or are there other sensors?
Thanks
andrew
Thanks
andrew
