2004.5 LLY
One day my truck decided it would not let me change the power/level of the air coming out. Sitting still no air comes out but when driving air will come through (very minimal). I can change the temp and zone but not the power.
I have replaced the Blower Motor and the Blower Motor Resistor and still no luck.
Thanks in advance.
Did you check the fuses that protect the fan circuit? Did you check to see if you had B+ power to the fan motor? or the Resistor? Did you check to see if there is a good ground B-?
Checked all the fuses. All good.
Decided to start back at the beginning before replacing the control unit.
It was the fan blower motor. I had just replaced it 4 months ago so it was still under warranty.
