1 - 14 of 14 Posts
BAD ASS LBZ that is
The next thing i am going to buy is a Airdog II. I know this pump has two filters on it i was wondering if it replaces the factory filter or just adds two more which seems like overkill. :confused:
BAD ASS LBZ that is
Discussion Starter · #2 ·
^^^ bump ^^^
So if i delete my factory fuel filter will i through a code?? I have the ad ii 165 just installed yesterday and factory filter is leaking??
NO, it will not throw a code-- disconnecting the WIF sensor nor the heater on the filter assembly will not trigger anything. :)
Not trying to jack the ops thread but would the extra fuel delivery make you go through stock filters faster? Or would the filtration of the airdog counteract this? Jw
your getting nothing but pure fuel to the motor you don't even really need the stock set up i would get rid of it takes about 15-20 minutes and not even a foot of 1/2 in hose all you'll end up with is better flow
check with Holton from alligator performance he has a good write up with pics
hey quick question. what is the size of threads going into the back of the cp3 inlet fitting? want to get a 1/2 barbed fitting adaptor so i can just run hose to it to delete factory setup
^^^Exactly.
There is NO point in using a stock 8 Micron filter behind a 2 Micron filter, utterly pointless. :drink
If you have the AirDog, the Stock fuel filter assembly should be removed and pat yourself on the back for not only improving performance but Improving the Fuel Filtration.
1 - 14 of 14 Posts
