well on my one and only day off i decided to do my install on the Airdog2 165 which was going relatively smooth until i came to the part where you have to cut the filler neck to insert the sleeve for the return line.
the problem is that there is a plastic tube running inside of the filler neck. the instructions even say that some 01-04 models have this and to NOT cut into the plastic tube but simple insert the tube inside of the sleeve and so on. well the problem is that the plastic tube inside of the rubber filler tube seems to be fixed at the gas cap and goes all the way down inside the fuel tank, i pulled hard and it seems fixed rigid.
anyone else come across this and/or know what to do? i have to drive my truck to work tomorrow so i have to have this fixed or i am screwed.
thanks in advance
thanks in advance
