I have an air dog 100 Lift pump with a SPD5 switch truck is slightly tuned and deleted deleted is the air dog 100 too small for my truck when I get on it it throws up code low fuel rail pressure
The AD 100 or FASS 95 will handle up to 600 HP which should be plenty for a slightly tuned Duramax. You would need to check if your fuel filters are dirty or if you are dropping pressure from the pump when applying a heavy load. Pressure from either unit should measure between 8 to 10 psi at the discharge side of the pump. Dean
2016 Chevrolet Silverado Duramax
When I installed my airdog lift pump, I, replaced the main filter on the engine also. Replace the main filter and see if that solves your issue.
Replace your filters depending how many miles on them and if it still happens send a log to your tuner
