1 - 20 of 20 Posts
I just spoke to an alignment shop about doing my truck next week after my lift goes in. He told me I would save some money if I free up the front end (cam bolts a-arms) does any body know what he meant by this? haha. He said it would make it faster for him to get it done because he wont be wasting time un-siezing parts.
dont tighten the upper and lower control arm untill you have full weight of truck on the ground
and what will this do? sorry i just dont understand
Dont most shops charge a flat rate for alignments? Around me it cost about $80-$110 for the dmax . wife's car cost $60 at farm and fleet
he told me 80 bucks but if they have to get into unseizing parts it costs more? This guy is legit too. He does all the local lifted trucks.
Save him time from having to fight the seized nuts. They may have to heated up to be loosened. time=money
say u tighten the bolts in the air and you set the truck on the ground it twist the bushing and wares them out quicker or if you hit a bump and it twist the bushing it will lower the truck and will change the alignment
^^^ this, Loosen the nuts and re-tighten them on your upper control arms where they mount to the frame, they can be a real pain in the ass...
You may have to heat them a little bit but dont melt the rubber bushings inside the arm...
i do alignment every day it sound like the people are lazy and dont want to do ther job, if you cant get it with a wrench use a air gun
ok, so when i install the lift, i dont tighten the control arms. Or do I even touch those during an install lol? I feel extremely dumb. I might just call him back and get him to explain in detail.
when you install the lift only leave the upper and lower control arms loose, when you r all done with the lift and the truck is on the ground you can tighten the upper and lower control arm, the uppers to 100 ft lbs and the lowers to 160 ft lbs
and that will make it easier for him to do an alignment? he mentioned something about cam bolts? is that the ones your talking about. lazy bastards eh.
the lift should come with instructions, if not you can google the instructions it will tell you what to do. r u buying the kit off of somebody or a company
the cam bolts r on the upper control arm
Shop owner must not think that you are going to loosen the "cam" bolts on the control arms thats why he is saying this, Just put the lift on and take it to him, shouldnt be a problem since you will have already had the bolts loose and they wont be siezed up.
just keep in mind when you lift a truck you can get camber back in to spec but caster will be a lower # then what it calls for most of the time. most of the time it will call for 4.5 stock when you lift it you will see from 1.0 to 3.0 wide range
If you want your camber to be right on you can buy Moog problem solver offset upper control arm bushings and they can get it dead on. When I lifted mine I did that and the shop said they never had anyone use those before doing mine.
1 - 20 of 20 Posts
