41 - 51 of 51 Posts
Supporting Vendors
After a road trip this weekend into the depths of Arizona I discovered that my low beams are projecting all their light to the right side of the road. It started after I put the HIDs in and I'm wondering if there is a particular orientation to pay attention to when installing HID bulbs in regards to the direction the arc should be facing?
Also, checked with the dealer and there is no side to side adjustment on the headlight housings. This sucks because it is a pain to get to the bulbs as I have to remove the driver side battery as well as the air cleaner.
Could you post a picture of what you are referring to? They will maintain a similar cutoff to the factory halogens, with a bit more output
Make sure the bulb is seated in the socket correctly
Nick C.
Discussion Starter #42
Yeah tonight I'll get a picture of what it looks like. I was careful to ensure it was set correctly but I'll take a picture and you can tell me what you think first.
Discussion Starter #44
Supporting Vendors
It's supposed to have a cutoff like that, so you don't blind people on the other side of the road. The factory halogen bulbs produce the same effect
Nick C.
Discussion Starter #46
Oh ok. I won't even mess with the bulbs then. Wish GMC had allowed for side to side movement.
Discussion Starter #47
Thanks to Nick and Justin got my 5K 35W Fog HIDs installed and they fit perfectly! Sent back the XML2s with their supplied return label and all is well!
Will the 9006 XML2 work in the headlights? I have heard a 9006 bulb will fit into the 9012 socket without any trimming. Just looking for confirmation before ordering.
Frogman, Looks like you ordered the 9006 HIDs. Any issues with them fitting?
Thanks in advance!
Supporting Vendors
Thanks in advance!
I wouldn't recommend an LED for low-beam use. HIDs are still going to provide more lumen output and a better output pattern. Especially in projector style headlight housings.
Feel free to give us a call if you need more information: (314) 205-3033
Thank you!
Nick C.
How did you even get your XML2's in? I have a metal plate on both drivers and passenger side that prevents them from even lining up with the bulb socket.
Discussion Starter #51
Nope ended up returning them for the same reason. Very happy with my HID fogs
41 - 51 of 51 Posts
